Your welcome, I'm a believer in the AGM, and convert the vehicles and boat. Too many positives, I think you'll enjoy it.
Same a any lead acid battery either a constant current or automatic chagerHow do you charge these?
So you are saying when you have 2 positives on one battery, that's a negative?If you have 2 positives on a battery there may be a problem with it....![]()
Looks good to me hows the garden coming my potatoes are really looking good this year everything else so soThis is what my small engine guy sells.
$ 85.00 Canadian. Good CCA at 200. That’s good I think.
Below is a interesting maybe a little boring read. But does explain differences.Be carefull with what chargers you are using with AGMs. First AGM I ever bought red top Optima, I found I needed a smart charger. This was about 23 yrs back.
In some situations the smaller size can be a huge benefit.I've ever bought, and the smallest as well.
I first wanted to use AGMs in my car when I first tried them out 23 years ago. Leakage/safety in an accident were the reasons I wanted to use this newer technology.As a fleet mechanic I see a lot of both AGM and conventional batteries. Both came as OEM original equipment in the vehicles we see.
Also I have one on my Harley
One thing about AGM that I have noticed. They sure cost more than conventional but definitely don't last any longer.
I had one in one of my Dakotas that got wrecked about 7-8 years ago. It was here that I saw what is (maybe) the AGM only advantage.
When I wrecked that truck though the battery was restrained by it's hold down, it wound up flying out of it's hold down and ended up several feet away in the intersection. There was no acid mess from the battery case having busted open
As far as lasting, I bought one last October for my Harley. I had a battery tender on it thru the winter. Come March it was JUNK already and I had to replace it again. Luckily they warranted it, but at $125 was the most expensive battery I've ever bought, and the smallest as well.
