You want it higher or lower..?This is officially on hold as the height was going to be an issue!
Much lower. But not needed right now. The LK is light enough (when the front deck is raised) that I could pick it up with one hand and stuff blocks under the tires!You want it higher or lower..?
Look here:How about putting your lift over the engine and use a chain over the lift & hook both side of the frame and go up from there?
Have you had any problems with various widths fittingMade this up for my hyd lift table. When the front wheels are strapped down, if needed I can jack up the rear and set the tires on milk crates. I have found so many uses for this lift table. Made an extension to make it wider for some push mowers. Strap stacked milk crates on it as a rest when cutting up 20 ft steel with the chop saw. Being rated for 1,000 lbs I set my 700 lb welder on it when refurbishing it. It's just been a handy helper for me.
Mike
Since I don't collect them and do little repairs for friends and neighbors, I haven't much variety to lift. But to answer your question, no.Have you had any problems with various widths fitting
