Swisher 66" Tow Behind Finish Mower Detailed Service.
larrybl
Swisher 66" Tow Behind Finish Mower Detailed Service. I be leave this is a 2012 model. I just purchased it and will be doing a complete service and repair before I use it.
We had one like that. Not sure the brand though. Just know it was red and had a 27hp kohler on it. When we had our big camp down in WV we used to town it behind a 4 wheeler. It did a fantastic job and it would chop up just about anything.
Plan is to get this completely serviced and tow it as an off set to my 50" Craftsman II (BOH). Should give me around a 106" cut with a 10" over lap between mowers.
Quick update, Part 3 coming soon! Parts have been shipped
While you are servicing everything check your valve specs they are supposed to be checked and adjusted (as needed ) every 100 hours.
Larry, would it work better to have your tow mower offset to the left side rather than the right? Would not be double cutting grass, have less thick cut grass windrows, and not be guessing where to drive as your tractor would cut like you normally would? Just going by what a friend does with the large area he mows with a similar tow behind machine, only a business sign post for obstructions but does highway road banks also.
Thinking of selling this. Just not my bag of Tea. New it runs $5,000.00. I am asking $2,500.00 Does this sound reasonable? Here is the ad I will be posting after a few more spare parts come in.
Swisher 66” Tow Behind finish Mower. $2,500.00
20 hp Briggs & Stratton Professional series engine, pressure lube.
Engine recently serviced.
2” Ball hitch adapter, can be easily converted to a Pin hitch.
Can be center towed, or off-set either side.
New Blades.
New Fuel lines.
New Fuel filter.
New Air filter.
New Tires.
New wheel Bearings.
Spare parts provided.
Manuals on CD Disk. (Operator and Repair).
New Caster bearings (not installed) as the ones on it are fine.
New Coil (not installed) as the one on it works, but a mouse partially chewed the wire.
Spare set of blades.
Spare set of belts.
Spare wheel bearings (2 sets that were still good)
Spare tires if you want them. (They are filled with slime)
Extra Engine Service Items, (1) Oil Filter, (2) Qt’s Oil, (1) Spark Plug, (1) Air filter, (1) Fuel filter
Compared to New ($ 5,099.95) new.
