Exactly what I was thinking!It would be nice to find a small Diesel to put in.
Unless it was a VERY low hour take out and over 50hp. that price is way out of line.he had a small diesel he would part with, for $3500.
Hope you can hear it run first!I bought the ch20, I’m going to pick it up Saturday.
They have the newer ones leaned down to satisfy the EPA and CAL specs.You'll have to post how the power feels after the swap.
I've always felt like the older engines feel more powerful than the newer engines. For example, 25HP in a new tractor doesn't feel as strong as the 12HP in a 1970s cub. Could be gearing, ect, but the older engines always seem to have more torque.
What does the epa restrict on these small engines?They have the newer ones leaned down to satisfy the EPA and CAL specs.
Non adjustable main jets for one. That tends to make them run lean when new, and when jets get a little buildup in them, they run even leaner, which in turn makes the engine run hot. Then you have valve seats and valve guides coming loose, among other bad things.What does the epa restrict on these small engines?
