The bent push rod was probably the problem all along. My grandpa has a IH 140 that will run fine for months or years then suddenly start running poor then skip badly. Every time its been a bent or broken push rod. Usually on the # 2 & 3 cylinders. Never found a reason for it either. Had the head overhauled and it still does it and I've run into a couple other people that have the same issue. Most of the time I just pull the valve cover and straighten it as best I can and run it again until I can get another good one to put inPulled the head to get a look inside. The #3 intake is stuck and #4 intake is sticky. All of the other valves are good. Still not sure what the problem is.
View attachment 12380View attachment 12381
Is that rust I see in those combustion chambers?
Mike
Coming along there! Good to see some progress!
