Got back at it. The center bolt on the cap for the sprocket came out fine. Of the three bolts around it two twisted off. Once I got the cap off I welded nuts to the bolts that twisted off and then they came right out. The big bolt that clamps the sprocket to the axle was very stubborn. The 3/4 impact eventually turned the nut and after
I turned it back and forth for a while the nut came off. Tried the 3/4 impact on the bolt and achieved nothing. Heat beat more impact nothing. Got out the I" impact, Same results. Center drilled the bolt all the way through. More heating and beating, Nothing, Used the 1" impact again and finally twisted the head off the bolt. At this point the bolt has not moved at all. So now I drill the bolt out about 7/16 and burn the bolt out from the inside. Not to bad a job since it was already pierced with the drill.
The bolt hole came out clean enough. Now to try to remove the sprocket from the axle without breaking it.
I have applied lots of heat, had cheery red at times but not all over at once. I put a plate over the end of the axle with three appropriate holes and three 5/16 bolts. According to the specs this should apply about 9000 lbs of force, the sprocket didn't notice.
Had a wedge in the split in the hub with no detectable effect
All I can think of now is to just keep worrying it and hope it gives up. Got all the oil burnt off of it now. Think a little muriatic acid would help? I am open to suggestions
Don.
