The R/T tractor and the Shaw conversion tractor both have foot operated brakes as well as a hand operated parking brake.
In using both of these tractors I have realized that it isn't necessary to use the brakes most of the time because they both slow down as soon as the clutch is pushed in.
I do set the parking brake on both of them when I'm showing them so that the tractors don't accidentally roll if someone leans against them.
So .... taking this into consideration along with the fact that I do not have another pedal to match the clutch pedal on the Centaur tractor.
I have decided to just put a hand operated parking brake on the Centaur tractor and of coarse this parking brake can also be used as a regular brake to slow the tractor down when I'm driving it.
I took apart a foot operated emergency brake from a mid 70's car to get the ratchet gear and the locking pawl from it.
The ratchet gear is mounted to a bracket that bolts onto the tractor frame and the locking pawl is mounted to the arm of an old implement lever.
This parking brake lever unit is mounted to the left side of the steering column.
A cable is fastened to the bottom end of the brake arm and the other end of the cable housing is attached to a bracket that goes up over the drive chain.
Because the original conversion was built using mostly square head bolts, I am also using the square head bolts whenever I can.
This is a side view of the bracket that I bent up to go over the chain to hold the brake cable.
A side view of the brake lever with the brake released.
And with the brake engaged.
This is the brake assembly with the brake engaged.
And with the brake released.
I welded a pin onto the top of the brake band and this keeps the band held up away from the drum so there is clearance all the way around between the band and the drum.
The pin on the brake band fits into this adjustable saddle to hold it in place.
