My brother has had this work bench sitting around for years. His plan was to use it as a reloading bench. He came up with something else, so I asked him what he was going to do with it. He said take it. Pulled a plywood shelf unit out that was heaped with cr@p. Put the work bench in its place and cut a couple pieces of press board for the top and upper shelf. This will be a good spot to work on small engines, chainsaw, and whatever else we can think of. I bought a diesel heater to put in the container to take the chill off. I think I can easily block off half of the container to make it easier to heat. The chainsaws were just lined up on the floor before and now they have a home on or under the work bench.
