I got the carb put together and installed. Figured I should try to start it so I pulled the plugs to shoot some oil in each cylinder. I noticed some rust in the 2 front cylinders. I shot some WD-40 and oil in and turned it over. That seamed to cut the rust and I could then see a shiny cylinder wall with a nice cross hatch pattern in it. Put the plugs back in and gave it a try. It fired and quit around 6-7 times and then began to run. It sounded like it was only hitting on 2 cylinders at first and then picked up the other two, but would occasionally one would drop out. I think I will check the plugs again and maybe do a compression test. With the rust in the cylinders I may be fighting a sticky valve
