Sears suburban 18/6 rebuild w/ Predator 420 swap
Pulled the stock muffler off the predator, removed the spark arrestor and then removed muffler from the "header". I ended up drilling a couple 1/4" holes or so straight into baffle then into outlet pipe maybe allowing a little more flow. Also port matched the header to muffler a little, I could see an exhaust ring where they didn't match up. May not help, but makes me feel like it does haha. It really didn't make it louder at idle or fixed rpm, but it is louder when quick revving and will pop a little, sounds kind of cool. I think I'm going to cut and just move the muffler once I get hood ready to go on.
@MFDAC may need some pointers on how you did yours.
Hopefully this will give enough extra flow to compensate for air filter and larger jet.
I also bought a new brass bushing for clutch idler, the pulley tilts sideways a little when engaged, hopefully this will line it back up.
I think I took some pics of modifying the exhaust manifold if that is what you are referring to, Marty? I wanted mine quiet as possible so there was no substantial modification to the muffler, just the pipe and the grill surround notch.
I don't have time tonight, but sure will find what I can tomorrow night after work!
I remember seeing pics on GTT, I can go back if you don't have time to find any.
Whay type of pipe did you use to extend? I guess this is just steel? Grinds like it is.
Hey Marty, it took me a bit to remember what I was seeing in the few pictures I took. Memory sucks sometimes. I did have a pretty lengthy post on GTT about doing this repower and there were several attempts and changes along the way.
It looks like I cut the Honda clone exhaust , added a black pipe 90* elbow and welded it back together. Probably not "port matched" very well like you are trying to achive---LOL! Originally the muffler stuck straight up and I wanted it sticking out the side so I wouldn't have to chop up the hood. Here's a couple pictures.
Exhaust before being cut. Muffler removed.
This pic is after cutting welding and fitting. I oriented the muffler mount flange so the discharge points straight down.
I know that welding cast is more of a process than I did but it seems to be working for 3 years now.
Ignore the pipe on the left, I didn't use it.
Finished product
Hope this may help, Marty.
Finished product
Yep, that gives me ideas, thanks
Here I had to make a temporary belt guide, 3/8 bolt with an old socket LOL. I plan to fabricate a metal sleeve around the pulley.
The PO gave me a foot pedal, decided to add it, wow what fun with will be. Now I can clutch and gas like a car LOL. I removed the spring washer from the stock 420 throttle setup and left bolt lose then hooked up cable, works great. There is a second location to hook up a cable, once I get dash on, I will had a cable so I can then set rpms where I want if I don't want to use pedal all the time. I will also add a battery and add another charge stator under flywheel as they only have 1.
I am going to add a momentary push button to kill it as for some reason my switch quit working. I can unplug the low oil sensor, connected that little box to a button/ground and kill it for now.
Sorry to necro post on this one but these tractors are getting rare
I have a ss12 with the tecumseh solid state and I just swapped to a predator (6 I believe) and I’m looking for ANY help on how to mount/fab/replace the “clutch” pulley
It was bolted to the top/side of the tecumseh so not sure if I should chop it up and try to make something??
Welcome.
Not sure about getting rare, Sears made almost 1.5 million of the suburbans from 1959 to 1980, I myself have 9 of them and a couple parts tractors.
My 16/6 has the clutch assembly mounted to the side of the tractor, but here is a couple videos that might give you some direction.
