There is no hydraulic 'float' in the installed valve, so not yet. But I hope to 'add' on the 3-spool valve from a 140 that does have a 'float' spool. That will make the tractor an 'H-4'. I'd just swap valves, but the steering column is in the way of the levers/linkages.Another interesting thread I have missed lately! Since I have recently been re-designing the home made hydraulic blade on my MF8E there is plenty of stuff to learn here!
Do the hydraulics allow for blade float, Kenny or did I miss something reading along here? I put up with a rigid setup for a quarter of a century on my MF8E before I hated it bad enough to change it up. Geometry was messed up for angling the blade too. Those changes made such a huge difference in the quality of plowing and back dragging I can do now! Will you also have to get off the tractor to angle and lock the blade? That is my next hurdle that will require some miraculous engineering I think. I'd sure like to be able to do it all from the tractor seat someday!
I'll never wear them out!I am wondering why you didn't weld the second plate of the shoes under the bent one? If the shoe wears out it would be easier to remove the worn plate under and weld another one. Anyway my consideration is probably excessive as those shoes seem quite heavy duty in the first place![]()
From where?I was able to order the hoses and new connectors this week! Be back on this when they get here!
Surplus Center!From where?
