I recognize those pictures. The old mind needs a kick start now and then. Thanks.This is all I could find, but I will post some other pics.
Drained the Electrolysis Tank | Tractor Fanatics
I know the feeling well.I recognize those pictures. The old mind needs a kick start now and then. Thanks.
Do you feel like you're going around in circles?Cleaned up a couple wheel centers and one more rear wheel.
View attachment 52830View attachment 52831
Yes I do. Once the wheels are done the worst part is over. Then I can get to the fun parts. I don't have to much more time to spend on this with hay season approaching so that will consume most of my time till mid August.Do you feel like you're going around in circles?
2 more front wheels cleaned up. Still need to sandblast to get all of the nooks and crannies. These are decent wheels that won't need any repair.
<<< The heads of the bolts were really bad, so I drove a smaller size socket on the seat bolts and ground flats and used vice grips on the platform bolts.>>>
Several years ago I got a set of special sockets for Christmas. Believe they come from Sears back then. Set of 6 that covers 2 sizes of nut or bolt head each. Have a series of pins inside the socket that grips the damaged bolt head or nut. Have used them several times and are a life saver. Neighbor had a oil drain on one of his big tractors that someone really messed up. Took some wiggling etc. to get the socket completely down on the plug head but it turned right out.
I think I remember seeing that type of socket. Might need to look into getting a set.Several years ago I got a set of special sockets for Christmas. Believe they come from Sears back then. Set of 6 that covers 2 sizes of nut or bolt head each. Have a series of pins inside the socket that grips the damaged bolt head or nut. Have used them several times and are a life saver. Neighbor had a oil drain on one of his big tractors that someone really messed up. Took some wiggling etc. to get the socket completely down on the plug head but it turned right out.
If you didn't keep weights on them the cubs were known to be a little tippy.2 more wheel centers ready for a light sandblast. Pressure washed a hood and two wheel centers that were caked in grease and dirt. The hood is from our 1949 cub that was rolled over at some point in its life and tore the front corners out of it.
View attachment 52911View attachment 52912View attachment 52913View attachment 52914View attachment 52915
That reminds me I've got a couple of 154 fenders I need to do something with.Pulled a few more parts off of the Cub and started paint removal with a wire wheel. The wires are getting mighty short, so I need to pick up a couple more wire wheels. I ran one fender through the e-tank and got it cleaned up. It will need some metal relaced where its rusted out.
View attachment 53052View attachment 53053View attachment 53054View attachment 53055View attachment 53056View attachment 53057View attachment 53058View attachment 53059
