Free tractor
Both the throttle and spark advance rods are made up and installed.
Today I put on the fuel filter bowl with a shutoff valve and made up the fuel line going down to the carburetor.
I decided that since the fuel filter is right over the engine, I didn't want to use a filter with a glass bowl so I found one with a brass bowl.
I have the spark plugs out and cranking it over to get #1 on TDC so I can set the distributor.
# 2 and 4 have good compression but #1 and 3 have no compression so obviously, a couple of valves must be stuck open.
Time to pull the head.
I probably should have done this when I first got the tractor but the engine turned over so easily that I was thinking ( or hoping ) everything was okay inside.
The cylinder head is back on the engine and #1 piston is a TDC so I can set the timing.
The model-A, 4-cylinder engine has this pin threaded into the front of the timing cover.
To find TDC on #1 with the cylinder head on, this pin was un-screwed and turned around and stuck back into the hole.
There is a small indented spot on the front of the timing gear and the engine crank was rotated until you felt the tip of this pin slip into the indented spot.
Before I put the head on, I used this pin and I was not able to feel the indented spot with the pin.
With the head on, I'm not going to be able to find TDC again later if I need to.
So I ground a notch on the back flange of the crank pulley and made up a marker point out of stainless to mark TDC.
The distributor is mounted solid in the head.
The center shaft in the distributor has a collar on it with a notch in it.
They make this special tool for rotating and holding this collar.
To set the timing, you hook a test light between the wire on the points and engine ground.
The collar is rotated clockwise until the test light just comes on.
That means the points have just closed.
Then, holding the collar firmly in place, you tighten the center screw to lock the collar in place.
The rotor is pushed down onto the collar and the distributor cap is put on.
Hook up the four brass strips between the distributor cap and the spark plugs and the distributor is finished.
The spark advance rod is bent on the end to fit down onto the lever on the steering column.
There is nothing to keep it from laying over and rubbing against the edge of the throttle bracket on the head.
I made up a retaining clip out of stainless wire and a small spring.
One end of the wire fits under the front edge of the throttle bracket and the other end fits down over the spark advance rod.
One end of the spring fits onto the wire, then goes under the rod and fastened to the back edge of the throttle bracket.
This holds the spark advance rod up off the engine.
The lever on the steering column pulls the rod down some when the spark is advanced but the rod is still held up off the engine.
The 1928 - 1931 Ford model-A cars, pickups and 1-1/2 ton trucks all have the serial number stamped on the side of the engine above the water inlet fitting.
This engine does not have a number stamped on it and that has always baffled me.
After doing some searching on the internet, I found that, starting in 1932 with the model-B, 4-cylinder engines, the cars and pickups still have the numbers stamped on the side of the block but the 1-1/2 ton trucks have an area on top of the bellhousing where the numbers are stamped on it.
I had to use my small air powered belt sander to clean the rust off to find the numbers.
Then I went over them with a felt tip marker and sprayed clear over the area.
This serial number was issued in early December of 1933.
Hi JD so is this engine a Model B engine? I like what you did with the advance rod and the TDC pointer
