Dad had to pull that shaft out of the machine 6-7 years ago to replace that drive sprocket because all of the teeth wore off of it. Couldn't get a replacement sprocket but dad had a used one with the same tooth count and diameter. The centers were different so dad cut the center out of the original sprocket, machined a shoulder on it, then bored the replacement sprocket out and welded it together. Took him 3 days to get it back running. That previous work made it easier for me because everything came loose with no torch work needed.You fix the stuff faster than it can break CJet! Nice work! You can darn near see the air in that tire---LOL!
This is what we are using. Valvoline Multi-Vehicle High Temperature Red Grease. Every auto parts store is the same around here and we need it for all of the hay equipment because we are on the last tube. I see I can get it on Amazon for 49.95 but it would take a week to get here. I guess there is a price to pay for not planning ahead.$8.50 each sounds awful steep for grease cartridges, CJet! Pay less than half that here for #2 general purpose.
Looks like the tire repair is going to get you through the season! At least you will have a lot of repairs done that that will get you through next season easier!
I checked the local farm and home stores this morning. They are all the same or higher in price. In this state we tend to have pretty high prices when compared with a lot of the rest of the country.Auto parts stores is not the place to buy grease or oil, unless you want to pay the inflated price for it. Farm and home type stores have various quality grease and oil for a much lower. Including Valvoline brand.
Fire danger from that, CJet! Hope there are no problems!Just finished the small baling job. Baler counter shows 96 bales. Going to haul them asap as we have some what are described as "dry storms" moving in. High chance of lightning up in the Cascades but only a very slight chance of precip.
They are concerned about it. We have had a real dry hot stretch for the last month. Sounds like they are getting lightning up in the hills now. It clouded over here for a bit but then things cleared up again. I did get all of the baled hay in the barn so I don't have to worry about it now.Fire danger from that, CJet! Hope there are no problems!
