I acquired a Ford 8n
I got the tire off yesterday. Here’s a few more pictures.
826D8CF4-1EA4-4908-86AD-DE7417B6ACFA.jpeg0F603BE3-033F-4B70-9481-31C08188E504.jpegF8F562F1-A013-4E71-A741-4A3321D2EEF5.jpeg063EB0E7-E9D9-41B9-8500-E2DE41816381.jpeg
I noticed some rot around the valve stem on the other side too. Hopefully it’s not much worse inside and can be fixed. I have to take care of that soon before it gets worse.
View attachment 87596View attachment 87597View attachment 87598View attachment 87599
Hate to say it Nick but that one don't look to good either..
Take a chipping hammer to it and it will tell you more..
You got to HATE how tire filling with calcium chloride over the years literally destroyed the rims.
Pink RV antifreeze is all I ever use for tire ballast. When on sale, it's $1 per gallon in the early Spring. Yet after 2020, I've not seen a deal like that in a long time.
If I fill these again, I will either use windshield washer fluid or antifreeze. Probably whichever is cheaper. I think I’m going to try it with just air first then decide if they need to be filled or not.
Kinda agree with you Nick on refilling the tires. Makes no sense if you're not planning on doing hard work or pulling with it.
Today's washer fluids are now a regulated formula by the EPA, it's mostly ethanol. In time, it will corrode just like the calcium chloride. :(
There are 2 antifreeze formula's. the unsafe for pets and farm animals and the pet safe. The pink RV/Marine is the safe stuff. Propylene glycol will not cause rust, it is very slippery, and we eat it on our BBQ ribs, in salad dressings, in soft ice cream and gummy bears. Yes, for real. It is an FDA approved sweetener and it's also in many diabetic labeled foods too. (and don't get me going about the FAKE black olives either).
The ethylene glycol formulas will eat thru today's inner tubes. And the stupid so called Long Life antifreeze (OAT or HOAT) has only 33% corrosion protection compared to the old school green stuff with 99% protection. Thus, the inside of the rims will rust sooner.
Now, there are full formulas for radiator pet safe as well, but you are correct in stating, 'which is cheaper'. Thus, it's either the Beet Juice or the pink safe stuff.
Cost wise, mounted wheel weights are the way to go. The 2N, 8N, 9N, and the other later models use these.
And even today, some of the Caterpillar machines use this too. You would only need 6-halves. They fit on the INSIDE of the rim, unseen really.
Over the years, I've seen these painted red, white or black.
Thanks for the info. I did not know that washer fluid was corrosive. Looks like antifreeze is the way to go.
No, windshield washer fluid is not corrosive to metals. However, undiluted windshield washer fluid can damage a vehicle's paint or rubber seals over time. The solvent in windshield washer fluid can also damage a vehicle's clear coat. To protect against this, you can use a sealant.
Let's take the top two washer fluids, Splash sold at Walmart and elsewhere ... and Homestar who makes many of the other brands like Prestone with a little EG added.
Splash SDS
Homestar SDS
Both are Methanol based.
Methanol-Induced Corrosion
Last updated: July 19, 2024
What Does Methanol-Induced Corrosion Mean?
Methanol-induced corrosion is a type of corrosion induced by methanol. It is a recognized problem in the gas and oil industries, pipelines, municipal sewage treatment systems, and a variety of industrial applications. Stress-corrosion cracking has been observed in absolute methanol.
For solutions with a methanol content of 50% or more, the corrosion rate of carbon steel is significantly higher in the aerobic environment than the anaerobic environment.
The effect of methanol on corrosion is more complicated in acidic environments; the risk of localized corrosion increases with methanol content even though the general corrosion rate appears unaffected. An associated risk with the use of methanol is that oxygen is more soluble in methanol than in water.
Pitting corrosion was observed when the methanol content was 50% or more. When present in large quantities, methanol may compete with H2S for adsorption sites on the metal surface and block the passage of H2S, resulting in the formation of an uneven iron sulfide film. A metal surface with an inconsistent protective film is more prone to localized corrosion.
Under acidic gas conditions, the presence of methanol can increase the risk of sulfide stress cracking (SSC) and stress-oriented hydrogen induced cracking. Methanol can increase the rate of vapor phase corrosion, which directly increases the risk of a top-of-the-line corrosion failure.
Normally tractor tires are filled 2/3rds up or right at the high side part of the rim as shown.
This allows left over air in the tire. Methanol reacts with this air to steel as stated above.
I would only use beet juice or the RV/Marine pink stuff for a liquid fill.
