And if I remember correctly I brought it home from Minnesota.That sickle mower sure has some traveling history now! South Dakota, Texas, now Kentucky?
Cvans how did you end up connecting the hydraulics? I have a D1800 I want to add a loader on but not sure where to connect into it or the location of the connections.Thanks Daniel.
Progress has been a little slower than I had hoped for. Heat and humidity has kept me indoors more than I wanted. The loader is off the tractor right now and is being painted. The diagonal braces are complete and made out of 2" tube running from the top of the uprights down to the front of the frame.
Have to do some more research on the hydraulics. This tractor is equipped with hydraulic leveling on the 3 point hitch. If I tap into the output of the hydraulic pump and install the wrong control valve there won't be any power to the 3 point. Hydraulics aren't my best subject so my old head is getting a work out.
When the loader is back on the tractor I will post more photos.
Thanks for your interest.
Doing the same thing to my tractor now. Do you happen to remember what size the bolts are that mount mounting bracket to motorFinished welding the cross member and painted it.
Now have the loader temporarily bolted to the tractor so the diagonal braces can be made Monday afternoon.
View attachment 1365View attachment 1366
