I've made up a drawing for these 110-112 tractor totes. See what you think of it. I shortened, narrowed, and moved it in towards the grille so the hood should open with it on there.Yeah I would invest in one for sure
It looks greatI've made up a drawing for these 110-112 tractor totes. See what you think of it. I shortened, narrowed, and moved it in towards the grille so the hood should open with it on there.
Yeah, I wanted to be sure the design was okay first. I can put the measurements on once I think that's the final design. Also, will depend if the brackets will be for the tote or front weights. Another thing to consider is the width of the frame for the tractor. The 112 and 316 I have are both 13.75" wide. Not sure of that width on different years/models. The 112 is a '74, the 316 is an '86. The drawing I have for the 322 weight bracket has different mounting hole locations than these.I downloaded your drawing Kenny. Nice picture no measurements. Don
The one I made up for the 316 holds 160 lbs okay!Beefy enough to hold the suit case weights? Might steal you bumper design without the "grill" for my 110.
Nicely done Kenny.. Impressed.. Didn't know you were into CAD.I am not happy with how the build turned out so I am going to rework the tote part to be like what I have drawn out. I am working on a set of 3/8" spring latches for the tote also. This will tell me if the hood can be opened with the tote up too. Stay tuned, may take a bit with the cold weather.
That is SketchUp Free. I do decent with it.Nicely done Kenny.. Impressed.. Didn't know you were into CAD.
I just do a Print Preview and do a print screen from that. Use PhotoScape to resize the pics. Then an Open Office file that I paste the pics into. Convert to PDF and I'm done.Nice Kenny.
how to you export out of Sketch?
