I sure hope so. I always fear something failing after I work on it.Gunna be great.
I was surprised that there weren't more leaks of oil, water, and gas. Hope it stays that way.Hey cjet I like it really like it. No feeling quite so good as when an engine starts and runs so nice. Maybe you should tell your cousin that it needs to stay at your place for the summer to get it broke in so he doesn't have to worry
Always a nervous time no matter how well you know you did the work, as even brand new parts can fail. Wishing you the best!I sure hope so. I always fear something failing after I work on it.
Miracles do happen. The JD 60 runs again after 25 years. After filling the carb with fuel and the radiator with water it popped on the first revolution of the starter and after choking for a couple turns it came to life. It seems to rum good. The oil pressure came up right away and the charging system is working. When filling the radiator, we noticed the water pump was leaking out the weep hole. After running for a while, it is still leaking so my cousin is going to order a new one along with a new exhaust pipe. I guess after 25 years some things are going to get lost. Need to finish tidying up the wiring, change out the water pump, and get the steering shaft, hood, and grille installed and then maybe it can go home.
Thanks, GB. Good to knowHi cjet a simple diode is really easy to install inline but what ever works is good also a red warning light installed in the dash or a resistor also works
After looking at it some more, I think the bolt flange wasn't in the proper position when welded. It would take a lot of careful grinding to cut it loose from the pipe. Probably more than a guy would want to do especially after paying for a new one. Also found if the pipe is not center in the muffler mounting flange you can't bolt down the muffler.Yea that's not good it is aggravating when parts don't fit or align, a guy almost hates to cut and weld a brand new pipe
Sounds to me the seller needs to send a good replacement, I was wondering if the flange maybe didn't squared before welding, that would be a lot of grinding to get it off and alignedAfter looking at it some more, I think the bolt flange wasn't in the proper position when welded. It would take a lot of careful grinding to cut it loose from the pipe. Probably more than a guy would want to do especially after paying for a new one. Also found if the pipe is not center in the muffler mounting flange you can't bolt down the muffler.
I agree. My cousin is getting anxious to get the tractor back, even more so after hearing it run. Every time he has to order new parts it's another week that goes bye. I've about run out of time also with hay season upon us. If the weather cooperates, we may start cutting in 2-3 days.Sounds to me the seller needs to send a good replacement, I was wondering if the flange maybe didn't squared before welding, that would be a lot of grinding to get it off and aligned
