Not from me throwing it. LOLGreat you got it going. I bet I know how the tank got cracked.
Noel.
I was watching mine & like you mentioned it needs a couple of fender skirts. Good idea on the plates I hope your license plates are still good & not expired.One thing I found out quick with those machines is they like to throw dirt to the side. If you till close to lettuce or any head type plant, good chance they will throw dirt onto the forming head. It don't wash off ! So either make sure you keep it away from forming broccoli, cabbage, cauliflower, etc. or put a side shield on it to keep the dirt contained or you will have dirt in you produce when harvested. I used an old license plate and put one on one side of my Ryobi this morning.
fuel lines are the 1st to go wrong with a Ryobi and the primer rubber boot ,no matter what the unit isThis thread got me going, I placed an ad in Facebook last night and got an answer that this guy had a couple at the local flea market. Went over on my lunch break today and picked these 2 up. The Noma started after a few pulls. The Ryobi, the fuel lines are rock hard and I will fix them before trying to get it going.
View attachment 14086View attachment 14088
Those tiny carbs are not owrth messing with. Throw it away and put on a new one. Primer bulbs are easy to come by as any small engine shop has them in a couple different sizes.
I agree....Put on new fuel lines. Can't find a bulb so have a few ordered on eBay (5 for $4 from China)....will take forever to get here. Plugged up those lines and with a bit of choke it starts. Runs like a top.
The other one, I am having trouble with. Took the carb apart, looked clean. Blew it out, but still like its running out of gas.
i get
i find my near new primer bubbles from old weed eaters ect from the city curbside some are still pure clear still , i'm just a cheap scape lol
poncho62 i see one problem i have with mine over your tiller , i don't have long handles to control the unit with so it's harder to hold as well so i might look into doing something for a better handle set
I had a few minutes to look at my Mantis. A quick search for a new carb showed a Mantis for $75, and a bunch of others in the $11 range. Mine needs Carb C1U-K82 part# A021001090...... any suggestions as to where to get one (or several for the shelf!) based on anyone’s experience?Easiest way I found to fix a finicky carb on the Mantis and Echo weedeater is to just buy a new carb. Had the new carbs on them for about 3 yrs. Every fall the tanks are emptied and run them 'til they die. They've both worked well with this method. I think one thing that has helped is to buy only non ethanol gas for all my small engines.
Mike
