Same here! I can only stare at a screen so long, be it TV or internet.I'm not so worried about wrenching, more keeping my sanity by getting out of the house.
Yep! At least out there I can think about what I want to do that day!Same here! I can only stare at a screen so long, be it TV or internet.
That's why I keep 40 in the house during the winter. Don't spend near as much time in the recliner. The only down side is you use your microwave a lot more to reheat your food.![]()
That was meant to be a joke. Sorry.ou are one tough dude to live in 40 degrees! My nose would run so much I'd croak from dehydration before exposure---LOL!
Our home is usually between 67 and 68 degs. We turn it down at night to around 64 or 65 degs. I'd have hypothermia in a 40 deg. house.![]()
About 12" tall and wraps around one end! You can stuff a good sized log in there!I don't remember how big your shop is but that stove has enough surface area to heat a large area. Should keep you comfortable in the chilliest weather. What size is the stove door?
It's sitting on 2" thick concrete pavers on gravel, so no floor issues under it. I have the Hardi-Backer boards behind it on the walls. Shouldn't be a problem.Looking good there Kenny. How far off the floor do you have it? Insurance company I worked for required brick laid on edge with either a steel plate of a standard floor area for the stove to sit on. Air movement through the holes in the brick kepled keep the floor temp way down and the floor warmer in the room. Don't know how well it work but that is they way they wanted it.
