New work bench for the shipping container
cjet69
My brother has had this work bench sitting around for years. His plan was to use it as a reloading bench. He came up with something else, so I asked him what he was going to do with it. He said take it. Pulled a plywood shelf unit out that was heaped with cr@p. Put the work bench in its place and cut a couple pieces of press board for the top and upper shelf. This will be a good spot to work on small engines, chainsaw, and whatever else we can think of. I bought a diesel heater to put in the container to take the chill off. I think I can easily block off half of the container to make it easier to heat. The chainsaws were just lined up on the floor before and now they have a home on or under the work bench.
A helpful brother too, besides cousins! You're livin' the good life, CJet! Those are very handy benches. We had one in one of the work stations at my former job. While working that area I often though I should have one!
First job for the work bench. Installing the grille screen and mounting hardware on the John Deere 40 Hood and grille that I painted for my cousin. I should finish this up tomorrow and then I can deliver it. This is the only flat spot I have right now.
Now no flat spots---LOL! You make efficient use of everything you can CJet!
Getting the diesel heater set up. Found an old engine cross member from a GT/LT of some kind to mount it to. Added legs to make a stand for a test fire. I think I may turn them over after the test and hang the heater from the ceiling, but plans may change. Installed the fuel tank outlet after revisiting Gary's (MNGB) Kubota heater thread where he used a welding rod to slide the fitting down into the tank. Worked great. Need to mount the fuel pump, hook up the wires, and put some fuel in the tank for a test.
Somehow managed to get the heater primed and fired up. Boy that manual is a tough read. About all it was good for was to get me to recall some of the YouTube videos that I have watched on firing these things up. Let it run for 15 min. or so and it picked the temp up in the 40-foot container 2 or 3 degrees with the roll up door ajar for the exhaust. Now to decide on the permanent mounting location.
Let it run for about an hour and checked the temp. Outside was 47°F and the inside was 56°F. Like the above post says the roll up door was open about 8"-10", no insulation, and a 40' long x 8' wide x 9' high aluminum shipping container. I think if I partition it off at 20' it should heat pretty easy. May have to look into insulating also.
If you think of the walls on that connex as a heat sink then you'll start to get an idea what that little heater is up against. If I figured right you have 864 sq. ft. of wall space. Aluminum transfers heat far more efficiently than steal.
I'm guessing the heat exchanger in that heater might equal 1.5 square feet of area.
Your right some insulation might be in order when it's 20 degs. outside.
I do think your Container is going to make you a nice shop when your done with it and I'm following your progress with much interest. Keep up the good work. :thumbs:
At least the roll up door that we installed is already insulated. With all the stuff already hung/ fastened on the walls I'm not sure how to go about insulating it. I suppose If I put it on the outside, I will need to cover it so I'm not sure about that. I can do the ceiling inside pretty easily. It has a lean-to on one side so that would protect that side some. Things to think about anyway and it will take some time to gather materials.
You are right the supplied manual is pretty much worthless, good that you got it fired up and it working, here in MN without insulation the walls & ceiling would frost up and then it would rain. Maybe you could look into spray on foam insulation
here in MN without insulation the walls & ceiling would frost up and then it would rain. Maybe you could look into spray on foam insulation.
Under certain conditions it will get some condensation on the ceiling. I've heard that spray foam is fairly expensive. I've looked at this product before and thought maybe I should give it a try. I think anything that gives me a thermal break will help tremendously.
I used something similar to that and I put it up against a metal corrugated roof using construction adhesive. Granted you have to be inventive holding it up till dry.. Stayed put. Never had any come down.. Warn you though chickens love to pick at it....
