ATF will do fine and it really resists foaming.Finally received my order of parts late yesterday. May get to locate the valve today!
EDIT: What fluid would be best here? Power Steering? Low-vis hyd? Give me your thoughts.
Thanks Daniel. Wasn't sure which way to go! Gotta get a belt too!ATF will do fine and it really resists foaming.
We have rain today. Hang in there, I'll get back to it!Don't feel rushed. We'll wait. What choice do we have. Hurry up will you!
ATF it will be. The cylinder I am using has a bit of JD Low-vis in it, should mix I would think.Looks great, Kenny, hope the weather cooperates! I didn't get to post but I second Daniel's vote on the atf. That is what has always been put in the little hydo system on my MF8E and it's had Dexron, Mopar and Ford mixed through the years. Never knew an better 30 years ago when I got the tractor.
A little mix will be just fine.ATF it will be. The cylinder I am using has a bit of JD Low-vis in it, should mix I would think.
Now for the Cat-0 three-point! May be a bit for that due to weather!Looks great Kenny! Going to be a real back and arm saver!![]()
