Good luck, Jim! Keep us posted.I think the hours on this are low it’s too clean and the oil was in the hash marks and clean. I’m anxious to see if it runs.
That’s what I’m hoping DT just an adjustment. My curiosity is killing me on this. I have two tractors apart right now for rebuilding and an engine on my Cub 1250 that has a nice deck and plow with it. I really don’t need to be working on this right now especially during garden season. I have it in my shop so I can sneak a peep every now and then.They're adjustable(the clutch) that may be all you need.
It looks like it Lance when I get a chance I’ll pull that off and clean it up. Here is a pic of it as I was looking at it today.Sometimes rust and corrosion can cause the discs to stick to the pressure plates... I'll usually pull the clutch apart for a good cleaning and get the pressure plates resurfaced.
Your on it Lance I was watching some YouTube videos last night about the clutches and noticed everyone was using just one fiber disc. Once I get more involved in this I might have to pick your brain a little. I can see now why you pullers have so many different designs.That appears to be all original with 2 thin fiber discs and a metal friction plate in the middle.... not sure if those are still available but you can get a single 1/4" fiber disc from partstree and have the outer pressure plates resurfaced... its the same disc that my Columbia has but with 3 pilot holes instead of 4... or you can get an aftermarket Cub pulling clutch setup that has 6 pilot holes and stronger springs.... but you may get lucky if the fiber discs are not too badly worn you might get away with just a real good cleaning and resurfacing the plates.
Both of these coils are Diamond but made in Japan.Yup. Coils often marked with "contains internal resistor", "needs external resistor" etc.
I found a deal on feebay a year or so ago on some "Diamond" brand coils, made in Germany I think, have seen this brand on old VW bugs, etc
They had 2 versions, one of which they suggested for motorcycles, small engines etc and another version suggested for automotive usage. I think the internal resistor (or not) is the difference between them
These are brand new but old at the same time. I think I paid $10-ish ea for them now a days, a junk chinesium one in a parts store is 3x that or so.. .
