I forget but I measured the pivot pin with a cheap dial caliper and drilled the closest I could find. I've done 2 this way... Where the pivot passes thru the frame I welded washers on the outside of the ears, and in the middle of the lever that activated the clutch I welded in a spacer, think I used a piece of water pipe, and then drilled that pipe crossway and tapped it for a zerk. I did "ream out" the pipe so the pivot pin would slide thru but not be sloppy. As I remember one had a 3/8 or 1/2" bolt and nut, while the other had a rod and 2 cotter pins.... Neither of these were new tractors so I'm not sure which was "stock".
