One of those minor changes that turns into an engineering nightmare.Well, I'm SOL on the Kohler. Not enough room to make it work.
View attachment 30206 View attachment 30205
Gotta have the battery/fuel tank tray in there as the clutch pulley is attached under it. Pulleys were aligned well, just too far forward.
Yep! Can't get the battery/fuel tank tray out as it has the clutch pulley welded into it.One of those minor changes that turns into an engineering nightmare.
Don
More research before I unbolt the Briggs.Going to try the Predator after all then, or that Briggs?
I'll see what I can find. This Kohler is heavy, I imagine the Briggs will be too.they had a couple different clutch pulley setups on those thru the years whetehr they had a single or a twin engine, the "Roper" Ropers (not built to be sold as a Sears) ran Briggs C.I. engines, as did the 1 year only ('72 ish) SS 16 which was a derated 320000 derated from 16 to 15HP. That Briggs should go right on there.
Kenny the Kohler will work.Well, I'm SOL on the Kohler. Not enough room to make it work.
If I can figure out a fuel tank elsewhere, I may be able to build a different battery tray that is shorter. I won't go to Facebook!Kenny the Kohler will work.
A cast iron Briggs was offered in 71 and 72 in the Suburbans and they are the same foot and taller and a little wider.
The Kohler swap has been many times.
If you Google "Kohler engine swap into a Sears Suburban" or go to the Sears Facebook groups you can take a look at how others have done it.
I need to get more coffee in me this morning and I have to run in a few minutes but don't give up on the Kohler just yet.
They started with the SS16 in 73 by 75 all Suburban models had the tank under the seat.Which models of those had the gas tank under the seat?
Kenny I will do some searching later tonight when I'm at home.I can move the Kohler back 2.5-3" if I modify some things. Fuel tank will go behind the seat. May not get much done today as I plan to spend part of the afternoon with my daughter. But I have a plan.
That's true. I'm guessing the starter just sits higher in the Kohler.The OH series Tecumseh in those had a gear starter on them by the time Sears went to baby $#1t colored paint. Earlier ones had starter generator. I've had both versions over the years.
The crank height is the same on the Kohler as on the cast iron Briggs that was offered in 71 and 72.By moving the fuel tank behind the seat and turning the battery crosswise, I can move the engine back at least 3". I think the crank height is higher on the Kohler too.
