Same here Daniel when I see all the eco friendly stuff that usually means it don’t work.Being certified non-hazardous and "green" doesn't instill my faith in it, but sure hoping I'm wrong!
I seen that. The atf with acetone mix was the best on the one I seen.A fella on you tube did a test on a bunch of penetrant fluids and kroil came in last. Can’t remember what was first.
Might be worth the try! LOLHey Kenny since it’s eco friendly could you try a little around your ankles and shoulders to see if it helps...so had to say that. Thanks for giving us your tests. These days that’s the best way you just can’t trust the so called reviews on products.
Can't say for sure, but it did make it easier to break the rusted parts apart.So do you think Superzilla did it Kenny or would any penetrant have worked.
Once apart, it cleaned up nicely so I believe it did help. Smeared some grease on the flexible part of the cable and slid some heat shrink over. Heated that to shrink down so it's well lubed for some time now.Thanks for taking us through this with you, Kenny! Long as Superzilla helped, I would say it was a success!
The grease and heat shrink is a great idea, Kenny! I'll have to get some long heat shrink one of these days! Just have short pieces. I used to have a roll of wire and coil housing around here, left over from the go-kart days, but can't find it. Might have given it away with some old wheels and tires I had left over.Once apart, it cleaned up nicely so I believe it did help. Smeared some grease on the flexible part of the cable and slid some heat shrink over. Heated that to shrink down so it's well lubed for some time now.
