Rolled out the mower deck for the Elec-Trak.
Installed it and mowed a bit of grass by the shop to limber it up.
The Kubota with suspension under the seat/ fenders will be my main squeeze for the mowing season. But the Elec-Trak will be kept ready as a side piece.
Wow, Rick, that suspension in that Kubota would sure save my bad back a lot of pain in our rough yard! I like that front mower configurationon the Elec-Trak! Do you still have the other one?
Brought the MF7 and Massey trailer to the garage. Trailer needed new reflectors installed. The tractor has had a rear tire air leak for some time, turns out a loose valve core. I went to tighten the core and the whole valve stem snapped off, look original to the tractor. I broke bead enough to get a new stem installed. I brought the old MTD tractor to the garage to take off the rear lug tires before i take it to the scrap yard. I took off tires and rims with no issue. The newer MTD I picked up last year is going to the lug tires and wheel weights put on for my hilly yard. The newer MTD wheel did not want to come off. I was able to get one off and one lug tire installed. I had to order a puller so I can get the other side done. I did try to start the MF14 with loader but it will not fire. I plan on checking to see if it has spark tomorrow since it wouldnt fire with starting fluid.
I finished my trimming today. I had to run to town and get a couple cans of premix for the summer. Trimmed around both properties. Then I decided the 5 hedges that are at the property line needed to go. Fired up the chain saw and wacked them out and hauled them down to my dads burn pile in the back field. We usually accumulate brush and burnable stuff then have a big fire July 4th.
I swear the grass I cut yesterday is already grown! I had the deck set on 3.75. I usually cut at 3 but it was so think i wouldn't have gotten through it other wise.
