Shade? What is that you speak of? And a breeze would be nice!Changed the oil, cleaned the gas tank and finished assembly. Tools are put away and the camera battery is charging. Waiting on shade right now.
Try the drill trick I told Larry about.Want to fix mine next lol. A customer brought in a generator a couple years ago and I can't get the generator part going
I need to try some of this on the Hobart welder/genset here!I understand it has to be an old drill without a variable speed trigger. Gotta hold trigger in while you spin it. I've used this method myself and it worked. Now with my father in law's genset, the drill thing didn't work. So I simply used my jump box and applied 12vdc into the genset's 110 receptacle for a split second and the gen immediately came alive. I just ran the jump box ground to the genset's frame, then put a small wire onto the + clamp of the jump box and just pushed it into the + side of the 110 receptacle for a split second while genset was running. We had a drill in the other receptacle with the trigger lock on, and the drill instantly came on.
Guess I was lucky mine has an output.
when you say it quick 6 1/2 hp doesn't sound like much for a 4k generator. But it must be.From the Operator manual
Engine Specifications
–– Model. . . . . . . . . . . . . . . . . . . . . YF168FD-2-010
–– Displacement. . . . . . . . . . . . . . . . . . . . . . . 196cc
–– Type. . . . . . . . . . . . . . . . . . . . . . . . 4-Stroke OHV
–– Start Type. . . . . . . . . . . . . . . . . . . . . . . . . Recoil
And the sticker
Well, I have a Chinese clone generator, also 4,000 continuous watts, and it has a Honda GX390 clone, which is over 11HP. I ordered used Honda engine components to repair it. But in case I'm brain farting, when I go down there I'll check to be certain of what I'm saying.when you say it quick 6 1/2 hp doesn't sound like much for a 4k generator. But it must be.![]()
