I do love the belly disc plow it turns hard ground like butter.Very nice Farmall Cub haul. You will fall in love with the belly disc plow, as have I. I leave the disc plow on my cub year round, even when I put the front snow blade on, as there is zero interference, and all you have to do is hang the plow off the torque tube with a chain holding bracket. By the way, the video on post 15 of this thread was taken at the FCVAEC plow day the first year I had my disc plow. If you need setup advise let me know, as there is a special lift clevis for the plow.
Ya, I absolutely fell in love with the belly disc plow. At the plow day events some people hate to follow me because of the bowl furrow it makes, some because I dig deep with it. There are others that enjoy following my furrows because I actually leave a decent furrow.I do love the belly disc plow it turns hard ground like butter.
There should be a crankcase breather on that engine someplace. The oil filler cap, valve cover or breather tube. Make sure it's clean and and functioning properly.Starting to see a lot smoke out of the dipstick area when running.
Cleaned the cap the other day it was badThere should be a crankcase breather on that engine someplace. The oil filler cap, valve cover or breather tube. Make sure it's clean and and functioning properly.
