It has a front center and two back anti scalp wheels, I would like to see what would go there. Doesn't explain the rear bolt holes.Gauge wheel brackets?
Mike
Mike
KIT.NUT.FLANGE | Jacks | 532139729 | $5.24 | 3 |
Pully Driven | Jacks | 532136572 | $26.24 | 1 |
Pully mandril | Jacks | 532173436 | $8.39 | 3 |
washer spacer | Jacks | 532187690 | $2.09 | 3 |
Screw | Jacks | 584953901 | $2.09 | 9 |
Shaft Arm W lower bearing | Jacks | 532137553 | $24.14 | 3 |
Bearing 6024 | Jacks | 532129895 | $7.34 | 3 |
Felt washer | Jacks | 532153390 | $ 3.14 | 3 |
Bolt blade | Jacks | 532850857 | $ 2.09 | 3 |
Washer lock | Jacks | NLA | 3 | |
Washer blade | Jacks | 532140296 | $ 3.14 | 3 |
I like Pat's! Real easy to find what I need!Thanks for the link Kenny, Sense I have the housings I'll need to order all the parts below X3. Prices look much better than Jacks.
I've never had an issue with parts from there.Just ordered the spindles, bearings, pulleys, and bolts there. 1/3 the cost.
If so, they are 80 cents each at Pat's.By spindle bolts do you mean the ones that attach the housing to the deck.
Mike
