Both rear wheels were locked up on the tractor. Today I cut the drive chains off and removed the model-T rear axle.
Here is the rear axle on the lift cart. It turns freely when I turn the driveshaft and the pinion gears inside work properly when I hold one axle or the other while turning the drive shaft.
I was very pleased to find out that both rear hubs spin freely. It was the rusted drive chains that had everything locked up.
The front axle is removed from the frame.
The steering arms and the axle spindles are removed. I can tell right now that this axle will not support the weight of the model-A engine.
The back of the axle has a bar welded to it to keep the axle from moving forward or backward.
This part would probably work fine but I would feel much more comfortable with longer radius arms on each side that are mounted farther back on the frame. So I'm going to change that.
The size of the webbing of the axle is strong enough but there a weak area right in the center where the hole goes thru for the mounting bolt.
This area definitely needs to be beefed up.
