Yep. Tractor supply sells the woodenIf you can't have a proper breakaway, you might plan in a controlled failure point.
Wooden Pittman arm and a shear bolt on the arm mount might save you some heart and headaches
Awesome repurpose project.
Hi, I think it should be its 1/2" X 3" and there are two of them I guess time will tellIs the flat stock going out from the motor mount, under the cylinder, going to heavy enough, or does it get bracing?
If it looks like it might be bending, you could weld another 1/2" (3/8" maybe) piece underneath to make that one a 'T" bar. Would be plenty stout then!Hi, I think it should be its 1/2" X 3" and there are two of them I guess time will tell
