I don't have everything needed as yet for this, but I started making the bracket for it. First was the side pieces, had to cut a notch in these for some bolt heads sticking out that the 316 didn't have.
Then I set it on the table so I can put the 3" wide strap to set the width.
I got that welded in yesterday, but didn't take a pic. Here is the guard in front of the 316 to give you an idea of what I plan for this build.
I am going to look into using a couple mower deck spring latches to hold it up. Then I can pull them out and let it fold down with the bottom end against the side brackets to haul things. Stay tuned, more pics will be added today.
