John Deere 110
Who redid the engine got the valve spec mixed up they got intake at 0.12 and exhaust at 0.05 . I also found the head gasket was blown so it probably has a warp head if it not too bad I can use sandpaper and glass to fix it. I also dropped a bolt down in the blower housing so I got to pull the engine off to get it out. Probably will replace the head bolts while I'm at it.
I need to fix the steering too. Have to move the steering wheel alot before it starts turning. Here is a couple picture from today in the valve picture you can look and tell it way too much clearance
I just remembered I did pull the cylinder off it so the hose are open and it rained (sprinkle) earlier. I need to pull it tomorrow and bring it inside.
Painted some engine parts today.
