My fingers go numb when handling cold tools. Never used to bother me but I guess the circulation isn't what it was. I think -12°F is colder than we keep the freezer.  We got a little unexpected snow this morning. Might be an inch on the ground. Thursday the temps should be in the 40's for both highs and lows so I will get back on this project with a little heat in the shop.Oh yea 36*F is a bit cool to work in for any amount of time good thing you pulled the head but as you say it will clean up. Its -12*F here this morning but its bright and sunny suppose to warm some in a couple of days
I was going to hit the like button but I don't want to give you the idea that I liked what happened.Well, we have the first casualty in this project. After many attempts trying to get this valve out it finally started moving but got really tight again. While trying to push it back the valve head snapped off. Must not have had things squared up. Anyway, with the damage already done, I got the stem pushed out. Lots of dry looking rust in the guide. Probably need to get both the valve and guide but I will clean it up first to see what shape the guide is in.
Yea the guide looks pretty dry but it may clean up ok with a reamer I put that under Sh-t happens categoryWell, we have the first casualty in this project. After many attempts trying to get this valve out it finally started moving but got really tight again. While trying to push it back the valve head snapped off. Must not have had things squared up. Anyway, with the damage already done, I got the stem pushed out. Lots of dry looking rust in the guide. Probably need to get both the valve and guide but I will clean it up first to see what shape the guide iorin.
Good luck on the rest of it.
I really didn't expect this valve to be stuck that bad. I wonder if this port was the litter box for the mice and rats. The rest of the valves just slid right out.Yea the guide looks pretty dry but it may clean up ok with a reamer I put that under Sh-t happens category
