That loader was really abused. Did that sheet of tin ride home with you up there? (3rd photo) That roof lined up nicely !
I'm thinking your new Kubota could use a loader and I can make you a great deal on this one. Just needs a little TLC!!!!I seen that loader in the first pictures you posted and its bend I'm wondering how it got bent without shearing/breaking the mt bolts, anyway the tractor looks a lot better with it off
Cylinders look OK other than a little rust spots on the shafts. Might be able to polish them up so it doesn't hurt the seals.Hopefully the cylinder did not get bent so you can salvage something off the loader. Tractor is looking better already.
Don't set it aside for me cjet salvage what you can and call the scraper the Kubota is just fine as it isI'm thinking your new Kubota could use a loader and I can make you a great deal on this one. Just needs a little TLC!!!!The loader design looks pretty weak and its been broken and welded several times. I'm just wondering when I will find why it was parked.
Maybe because the operator was thown 50 feet to his demise when that bucket his something hard enough to bend that? Or maybe he lived through it but decided it was too much work to bend things back so it didn't rub the tires---LOL!I'm just wondering when I will find why it was parked.
Hope to paint it after I get all the bugs worked out. At this point I figure I will need to hone and re-ring it along with a valve grind. That could easily turn into a full engine rebuild. The other big expense will be rear tires. I have a set of used ones an a Farmall C but I may go with new if I can do the engine on the cheap. Just looking at options right now as I won't know what I have until I can run and drive it.Nice looking little bugger there Cjet....
Cleaned up good...
Get her running and put a little paint on her and it'll look like a million bucks.
