I appreciate the support from you guys on getting this old beater operating as it should!
Got it up on the jackstands, installed the front plate on the pump with the new seal in it, put on the filter and filled with 5 qts of fluid. Installed the driveshaft like it was. There was still plenty of daylight and it hadn't gotten too cold yet so opened the overhead door and fired it up. No hydro action at all. Looked at the driveshaft, and it had walked off the front splines and the pump wasn't turning. So, as a temporary fix, hose clamps to the rescue!
The driveshaft is spinning in the pic but the camera shutter speed is too fast to show it.
Didn't see any leaks or hear any bad noises so I operated the spool valve levers. Deck lift operated correctly as well as the 3 point. There was a noise when I put the deck lift in what I think is "float" but will deal with that later.
So time to push the pedal! Put it in low range and forward and reverse work!
Same thing with high range!
So you know what that means----drive the dang thing!
Threw the fender and seat assembly and steering wheel on and out we went!
I didn't remember to take a pic until I started to back into the shop after driving around a bit and testing reverse, as well as hi-low and neutral.
It has no brakes! The pedal in high range is abrupt in both directions but pretty smooth in low range. It looks like it will be a candidate to be a workhorse around here then. Plenty more to do obviously!
