Actually made pretty good gains on that dash tonight! I shoved the A/C under the door when I got home from work, and drilled holes for the amp gauge, front pto clutch and ignition switch. Put what's left of the plastic dash over the aluminum one and figured the amp gauge position is fine. Drilled it with a hole saw. Didn't like where the switches were so just drilled them where I wanted.
Removed the aluminum dash and hit it with 160 paper in the electric D/A sander.
Cleaned it with brake cleaner then gave it a coat of Dupli-Color self etching primer.
Let that dry a few minutes and sprayed it Krylon Satin Black.
Maybe I will get it put on the tractor tomorrow night after work.
