The MF1450 is sitting back on the ground. It looks to have a little bit of toe out yet but I adjusted the tie rod out far as it would go. I may have to build another one. It looks to be a quarter inch or so is all. Much better than the 2+ inches it was before. Camber on the LF is much better too. Greased the spindles and wheel bearings until I could be sure everything got some.
The curve of the camera lens makes it look like it's a foot or so toed out though---LOL!
I removed several brackets that seemed to be haphazardly bolted to the frame. a couple are bent and a couple appear to be broken off. No clue what they may have been for. Look to possibly be MF parts though.
I was informed today when I went to Harbor Freight that not only is there possibly a grease shortage, you must also present an ID to buy it. Apparently dopers have figured out how to make Meth out of grease! WTF is wrong with people? They had plenty of grease on hand though. I bought a couple tubes. I bought some wire so I can attempt to fix some of the electrical, and a filter for my shop-vac too.
Too hot to open the overhead door and take it for another joy ride though. Next up will be a dash panel and steering column support, along with mounting the old MF12G fuel tank on it.
