Most garden tractors have some sort of float built into there hitches I think Doug. My Fords have a slot in the lift arm from the cylinder to the sleeve hitch or tiller. You should be able to make a bracket to take the float out. Just my take on it.
The picture of the 3 point is of a MF 14. I circled the built in float part on those tractors Doug. I don’t know where it is on your tractor.
My John Deere snow thrower has a slot in it where the hydraulic cylinder, for lift and lowering, hooks to it. Even thou the tractor hydraulic lever has a float position.
If the rectifier is a three terminal, the middle wire is B. You do a continuity test from the B wire, with it off the rectifier, to the positive post on the battery with the key in the run position. You should have continuity. If not, you have a bad connection somewhere. And it will not charge. Stator check is take the other two wires, which come from the stator, hook up the meter to those two wires and set meter to AC volts. Run engine at full throttle and you should have 28 or more AC volts. If not, there’s trouble with the stator or those two wires. Hope fully I explained that right.
Noel.
I appreciate the info, Lance! That's a good looking setup! It might be a pretty small chance of finding small spring harrows out here but we do have a possibility. My wife has an aunt with a large ranch. There is a lot of junk laying around there and we have helped her son move some of the junk and even hauled a bit home. Seems like I remember seeing something like that there.My favorite rig for levelling gravel was these two 5' sections of spring harrows attached to a 10' length of 3" pipe... this works very well, easy to pull and I could drive alot faster than with any blade. Diamond harrows work well also but these sprine tines can also be used to aerate the grass.
I imagine that's possible, Noel, but when I switch on the electric pto it shows 7-8 amp discharge. No, didn't test battery voltage while running. I'll try that one too.Could the amp gauge be wired backwards ? Did you test voltage at the battery while running at full throttle.
Be sure to put the mat down over the grass before you add the rock. Grass will grow right up through the rock.Didn't get to work on any tractors after work tonight. I borrowed the measuring wheel from work and measured our acre property lines, driveway and a couple other areas, and met with a gravel hauler with a 6 axle 20 ton dump truck. In a couple weeks he's going to haul in around 30 tons we figured roughly to put fresh on the existing gravel, and add gravel over grassed areas I want covered. The hauling will be the cheap part. I haven't gotten a price on the materials yet. pretty scared to find out! My poor little tractors, especially the MF8E, may not survive spreading it! Going to try to get an attachment made for the 1450's 3 point that will help with this chore, for leveling and smoothing. Will want that to "float" so no sense thinking about locking the float out of the 3 point at this time.
Don't know where I can find one quick right now but it would work great I bet!An old bed spring work's well for levling out about anything, especially a new lawn. Cheep, pulls easy and covers a good size area.
I may have to fight it with roundup like the rest of the gravel. Going to get 2 15 ton piles here on Friday afternoon, and a neighbor with a bobcat will be spreading Saturday.Be sure to put the mat down over the grass before you add the rock. Grass will grow right up through the rock.
