Thanks, Jake, that's what I was trying to say above. Leave it off until the tuning is done. Yeah the manuals have that tuning info. Far as carb I.D., I think it's a chinese knock off of a Walbro. Not 100% sure on that one yet. Got adjustments to make on the governor when the spring gets here too, and possibly the throttle cable as well.Doug, I would suggest doing the main carb adjustments with the air cleaner off, its easier doing it that way. The manuals should give you the idle screw and main screw settings, you just have to match up with the carb you have, Carter/Kohler or Walbro.
That steering wheel turned out good Doug your wheel /press idea is good I like that your moving right along
Thanks Gary and John! Inching closer to trying to fire this thing!Nice job straightening out the stearing wheel Doug. Looks good.
jhn9840
John
That’s quite an idea Doug, to get the steering wheel fixed up. Your getting closer to start up.
Neat way to straighten a steering wheel!
Hi Doug the Carb is an aftermarket Carte/Kohler 30 not a Walbro just letting you know make tuning easier using the right specsThanks, Jake, that's what I was trying to say above. Leave it off until the tuning is done. Yeah the manuals have that tuning info. Far as carb I.D., I think it's a chinese knock off of a Walbro. Not 100% sure on that one yet. Got adjustments to make on the governor when the spring gets here too, and possibly the throttle cable as well.
Very cool Gary! Thanks again! Using your info I found the settings in the manual and did those adjustments tonight after work!Hi Doug the Carb is an aftermarket Carte/Kohler 30 not a Walbro just letting you know make tuning easier using the right specs
Just grab a spring from the neighbors trampoline. They won't miss one and it will get you going.till no governor spring.
A little stiff!Just grab a spring from the neighbors trampoline. They won't miss one and it will get you going.![]()
But the reaction time will be fastA little stiff!
No neighbors on either side of us for now! Wish I was rich, I'd buy both acres and keep it that way too! If anyone out here had trampolines, they would blow half way to Nebraska before I could rob a spring---LOL! Hey wait---I have some truck hood hinge springs out in one of the sheds!Just grab a spring from the neighbors trampoline. They won't miss one and it will get you going.![]()
Much better that way. Usually they say it's been delivered and instead it's nowhere to be found.Usps tracking for an order I got in the other day said it was on its way and it was on the porch when I got home.
Much better that way. Usually they say it's been delivered and instead it's nowhere to be found.![]()
It shipped USPS, and todays update says it is now in Rapid City. In this case, I don't think the delay was USPS. I think the seller printed the shipping label last Monday but never got around to shipping it until Friday evening.Your making progress, curios how is the spring coming US mail or other, I've found the USPS mail tracking to be just terrible at times there has been times when I get and e mail saying the VA has sent my meds when checking the tracking nothing a coule of times I had the meds and the teacking will say its on the way wha, back to your wiring I used yinyl spilt loon a lot and really like it vs trying to tape the wire then just tape the ends and use a zip-ty every 6-8"
No shavings Aaron, but there's a piece of what looks like clear cellophane stuck in there. Doesn't seem to have any wobble, trying to move the shaft by hand.Is there metal shavings around the shaft in the 2nd picture?
My aliens gt17 threw the seal out. I was able to cross reference it at a bearing house and get the seal for $5.00 instead of 35 that tractor parts place wanted.
