MF 1450
It sounded like this new to you LT is in better shape than Carolyn's? Might be worth doing the engine swap soon as you figure if the newer one is in good shape other than the engine. That K321 has sounded like it wants to ventilate itself since I got it running and after I overhauled it, it didn't sound any better. Now this situation is making me dislike bigger Kohler single cylinders quite a bit. The K181 in the JD 110 purrs like a kitten but was in as bad of shape when I got it.
Ranting again---sorry!
Got the Cub home but still on the trailer. Took the engine cover off, then the starter. Starter still won't turn. Used a small pry bar on the flywheel gears against the ignition coil mounting post on both sides and it would not budge. Locked up solid. Courage Kohler engine. Think I will unload it in the machine shed for the winter and see what shakes out next spring. Would have to swap hood and engine as there is some air intake moldings that have to go with a Briggs engine. Might get another engine and use Carolyn's as a donkey around here and put that little Bolens 775 in storage.
What HP is that Kohler, Rog?
Those have no "courage", worse engine Kohler ever made, most become boat anchors.
DAC, I talked to a buddy who pulls with the flathead Kohler K engines, he was to make sure the condenser is good and that is attached to the Negative side of the coil. He's found this is usually the main culprit of running issues as long as coil and points are good. I slapped one on my Onan last week, it will now actually run decent and not die when I rev it up.
The flywheel has no effect on timing either, he said many don't even have a key in them.
Oil was full and looked good. Lot of black oil, etc all over under the engine cover. Melted area near the right side hinge on the hood. He said it got hot and melted it. Mouse nest? First thing I thought of but no indication with the cover off. Head fins looked clean other than oil soaked.
PO said he mowed with it once and then would not start. That is when he mentioned that had gotten hot and melted the hood support bracket. Put put a big bulge in the hood? Will get some photos in the morning.
Marty, I read this on my phone this morning. Not signed in on the phone on purpose, because me and touch screens are enemies. Your post was a real wake up call! Of course this flywheel doesn't have anything to do with timing! This thing has points and external coil not a mag! I said "DUH" to myself when I read that! it took someone to beat it into my brain I guess. Thank you for checking in with your friend for me and happy to read that your Onan seems to be running well again!
Even though I'm still feeling under the weather and we have crappy weather as well, I decided to tinker with it. Using Marty's info I decided to check the condenser with a multi meter like I should have done a long time ago. I checked the one I removed first and it tested normal. tested the one out of that Dual point automotive distributor still in place bolted to the coil, which in turn is bolted to the engine. It was intermittent. One time it would work, next time nothing. Didn't make sense, if a condenser is bad it should just be bad all the time not just now and then.
Then it struck me that I missed checking the most basic thing in electrical systems. Grounds. Hooked the multi meter to the negative post of the battery and started probing around. NOTHING! The ground cable is bad! I don't know how it even tried to start the engine much less make it run a bit.
Built a new one out of an old automotive cable. It is way overkill, but it is too damm wet and cold outside for this sickly old geezer to go rob one off a junk tractor out back.
Grounds tested good everywhere. This engine has rubber mounts and a steel braid ground strap to the frame. Everything read it had continuity.
Of course I had to start it even though opening the overhead door wasn't an option. Set the carb screws to the specs and it did fire right up at idle speed. It didn't want me to close the choke though. Let it warm up a minute and as long as I took it very slow I could get full throttle and mid range rpms pretty decent. If I opened the throttle too fast it would buck, backfire and die though. That was enough with a closed door.
At least now it will idle and rev up and run ok through the ranges if I am very careful moving the throttle lever. When the weather improves, I will tune the carb better and hope for the best. Think I could actually use it again like it is!
2 steps forward and 3 back. This afternoon the rain quit and the sun came out. Figured I could tune the carb a little better with the overhead door open. Fought for it to even start. Bucking and pretty much acting like that compression release you guys talking about wasn't working. Got it to start on about half throttle and was able the hear a difference adjusting both carb adjusting screws at lower rpms and high rpms. Would sputter and cough quite a bit no matter what I did though. Out of the blue it backfired out of both ends, spitting gas and black smoke out of the carb and breaking the factory weld on the inlet nipple of the muffler! It kept running badly but I shut the damm thing off. Patience is getting short.
Haven't gotten any new ignition parts but I did check primary and secondary resistance of the coil, checked the plug wire for resistance while swinging it around and they were fine. Put the condenser on the ohm meter. It built up resistance properly and went to infinity, then switch to volts and the power leaked down like it is supposed to. I cleaned and checked the points too but probably should replace them as a last resort. Oh different spark plugs twice too. It smells like it is running rich now. I put the spark checker on it and nice strong spark that didn't seem erratic. I didn't pull the carb back off and put that float back to the higher level that the factory had it set at.
In other words that engine is running no better now than it had before all the other crap I tried with it.
I'm tired of reporting downer news so this thing will be going out back for the winter.
I have a 17.5 Briggs out back that seems to be a good engine. I don't like the tractor though. If you were closer you could have it. I bet it would pretty much bolt in Rog.
Going from a Kohler to Briggs in a cub takes more work modifying the hoof inside than it does putting the engine in, Did that change to Crolyns and had all kind of plastic pieces lay around left over before the hood would close, and then no light would work. Don't work out in the dark any more anyway, If it don't get done in daylight it don't get done or it waits till tomorrow.
