I have 2 with priming levers, but need rebuilt. Never seen a kit for any of these.That's one of first style of Kohler fuel pumps, I have one just like it. Plus, I got at least one that has a priming lever on it.
Thanks Tony! It's a new experience for me.I had a 224 and now have a 448.
My 1982 224 had hydraulic lift, maybe the first ones didnt.
You should feel a few slight notches in the travel control lever for speed control.
They are a little scarey going down hill without a holding valve (neither of mine have it)
It should have whats called "retard", meaning if you are about half throttle coming down a hill, lower the speed slightly and it helps keep it slowed down.
If you pull it to neutral...mine will lock up the tires.
It takes getting use to.
The brake was really only meant for parking.
One of these days i will change out my hydraulic control valve for one with a built in holding valve.
They also made a separate holding valve that could be plumbed in.
For tilling, there is a flow control valve that would help with the ground speed problem.
Hope this helps.
Tony
I could find that site in a search, Jake, but when clicking on the link to the site it says "site unavailable" unfortunately. I searched quite a bit last night for full rebuild kits for the fuel pump and all just showed the diaphrgam and block gasket. No "flapper" valves or any other parts.Then and Now Automotive has complete rebuild kits for the Kohler fuel pumps, you just need to now what type you have.
Just seen the same today Doug, don't know if they are doing maintenance on the page or not. Maybe have to see if they have a physical address and E-mail. They do have a Facebook page.I could find that site in a search, Jake, but when clicking on the link to the site it says "site unavailable" unfortunately. I searched quite a bit last night for full rebuild kits for the fuel pump and all just showed the diaphrgam and block gasket. No "flapper" valves or any other parts.
Thanks Jake, I'll look them up on Facebook!Just seen the same today Doug, don't know if they are doing maintenance on the page or not. Maybe have to see if they have a physical address and E-mail. They do have a Facebook page.
Most issues are the diaphragm leaking fuel into the crankcase. Don't know if this old pump would use the same one. But I will keep your fix in mind.Hi Kenny
Many Kohler fuel pumps are discarded because of leaking. the problem is the aluminum housings warp from heat. I take them apart remove diaphragm a put each half in the vise and draw file them flat again. and reinstall diaphragm or the rubber part. I clean the rubber with Awesome orange from dollar tree. By draw filing
you take file with both hands laying on casting filing away from you. I have repaired many and have and haves not found a bad rubber. I bought a Carburetor leak Detector from Pat's parts. It is a hand air pump it go's to 10psi . It is good for checking needle and seats. I use it on the fuel pumps. I plug outlet and pump up from inlet about 5lbs and spray outside with Awesome Orange and you can see where it is leaking and you can check again after repair. I was told about this a the portland In tractor show and it works.
I have an electric pump on it now. Starts real easy using it. May leave it that way and use this fuel pump elsewhere.The first notch on the speed control is for going down steep inclines. It will hold back and goes very slow. Free wheeling on hills is an issue with the early tractors until they made a holding valve.
I have disconnected the original fuel pumps and replaced them with low pressure electric pumps. Instant starting and no chance of fuel getting into the crankcase due to bad seals in the original pump.
I'm using a JD 54" blade cylinder.Neat. I’ll have to remember how to find that if I make one. Where would you get a cylinder that small Kenny.
