I started out ripping some old pieces of 2x4’s for the frame. Top and bottom some old 1x6’s I glued together but didn’t use. I only had a small piece of 1/2 hardware cloth so I covered it with the 2x4 mesh fencing then covered the bait area with the 1/2”. I have a hinged treadle trip right before the bait tray. When that gets stepped on it pulls a wire connected to a barrel bolt the holds the trap door.
I had to change the door three times. First I used 3/4” plywood which took too much pull to trip. I then went with 1/2” which worked good but warped and failed to drop all the way down because of so much dew overnight. Carol in all her support told me he had a buddy that held the door up . My trail cam was placed too high and the trap wasn’t in the pics at all Yesterday I made a metal door using some 1/16th sheeting. This works really well and actually is no heavier than the 1/2” plywood. This morning nothing caught but the bait was still there. Im using peanut butter with a few mini marshmallows for bait. I can’t use any meat because of our cat.
