i had to do a one day axle to diff mod on the Rover Rancher 2 , the 1st thing was to strip all the unnessercery parts and straight axle out
View attachment 5502 that meant cutting out the mechanical disc brake as well , all the parts i will keep as i got another Rancher 2 i want to restore back to original look .
here is the Bolens ST 120 diff just set in place with the same drive belt set ready to make mounts for ,
View attachment 5503 then 2 pieces of 1-1/2" angle steel 3 " long done it nicely
View attachment 5504 and the front heel & toe linkage coupled to my pedal after a 3" extension no other mods to that bit ,
this is the front support mount plate for the diff i welded in and drilled
View attachment 5505View attachment 5506and a pix of the tractor in limbo , the diff set ready to mount ,had to replace a tube in the 12" tyre and sleeve the tyre wall and top the oil tank with oil ,
All is done and finished an workin well , it's way different to the belt clutch system an gears
View attachment 5507 the mod itself was very easy for a change ,
it took me longer to ponder what diff i was going to use than to strip and replace it , i had the option of the bolens st120 hydrostatic or a 5sp transaxle , the hydro won
Shane
