I had a MOOG ball joint fail after 4000 miles city driving. Definitely not quality, just a name. Warranty only covers parts, not labor.Saturday, Raked the yard of leftover leaves and all the cottonwood branches that have dropped. I don't know-how these trees live with as many limbs I pick up constantly.
Screwed my back up sometime Friday or Saturday, barely slept last night and in good amount of pain just standing/walking so no work today and I may call off tomorrow and try to get into chiropractor.
I did work on my wife's Liberty last weekend.
I bought Moog upper control arms/ball joints. I replaced the one within 6 months ago, one of the bushings are already shot and causing a banging noise. Can't even buy quality name brand parts anymore.
Moog use to be the better parts back in the dayI had a MOOG ball joint fail after 4000 miles city driving. Definitely not quality, just a name. Warranty only covers parts, not labor.
Nicely done Rick very creative. I bet that was fun drawing out the quilt patterns. I bought Carol one of those wire rack type wagons several years ago. She used it a few times but was way to heavy to pull around and she never cared for getting a tractor out. She said all I want is something small, lightweight, and easy to pull around. I got her a Gorilla cart which is a little pricey but very well built.I had a work in process wagon that needed finished. The wife will use it for working her flower beds. I had built a 2'x4' box to fit it.
The wife found a table runner design that she liked. so I used that as a pattern to decorate it. After laying out the pattern it took a few days to paint it. It has a removable handle, so it can be pulled by hand or with a G.T.
These are the same design as before and they kept coming back for 11 years and having 2-3 babies. Last year the bluebirds kept going in so I read this is common between the swallow family and bluebirds fighting over the same nest. They recommended adding one 25’ away so I have three spaced out along the back yard fence.Not sure your birds are going to like that tin roof as they like to land there. Hole for the Tree Swallows is recommended to be 1-1/8 high by 2' wide. The swallows can get in and out but dentures the sparrows. Nice looking bird houses and don't take much material. Later I need to build a couple to replace some that are falling apart from old age and use. Have some old barn boards that works great. We have Barn Swallows in this area. They build on about every building we have including the house. No mosquito problem either between them and the bats.
My last work van was a 1992 Dodge B250 long bed. The last five years I drove it before I retired it had a broken header pipe bolt. It would run quiet for about a year then start getting loud. I would back the other studs out slightly then slide a new gasket in then it was good to go again. I done that three times before retired and I sold it. It was a tank and served me very well.I have a WHOLE LOT of house repairs I gotta tend to this year. Been putting them off way too long.
Today is garage day, got my new heater box back together, all new foam seals and such, swapping heater boxes in my old truck to one that has AC.
I started with 3 factory ac heater boxes and will wind up with 2 good ones. One for my truck and one for the kid's. (His is already factory ac but his box needs to come out to clean all the leaves and such out so it can actually flow some air.
I have I heater box worth of junk parts. Cracked housing here, bad heater core there, bad diaphragm there for switching airflow, bad foam on the doors within, etc. I sacrificed the worst cracked up heater box (was busted up bad anyway) to cut out a small patch to fix one that had a small hole punched I to it...
Gotta get my table knocked down and tools out away cuz tomorrow is looking ugly.....
I think my son is bringing the daughter in law's Yukon over to use my lift, he's been complaining about loud exhaust lately, started out a little last week, but is all of a sudden much worse, sounds like I'm gettin suckered into an exhaust manifold job
Including having to drill out at least a couple of studs.... They have the bigger motor in there ... 6.0? 6.2? Something like that. Fun fun ...
Sorry I meant bolts where the exhaust manifold bolts to the head."header pipe stud"? You talking where the Y pipe bolts to the manifold? No studs there, they had thru bolts. And no gasket, the y pipe flange was bell'd out and the manifold was cast with a mating flange. No donut gasket needed too.
I had an 87 B250 window van several years ago , one that I should have never sold. Last year for carburetor 318. Was a damn good one. Don't remember what we wanted, that we sold that one in order to get, at the time.
87 was not the last year of the 318 carb. Before my 92 B250 I also had a 1988 B250 with a 318 that had a four barrel carb. Even though I rebuilt the carb I can’t remember if it was a quadrajet or a thermoquad. My 92 had fuel injection.I had an 87 B250 window van several years ago , one that I should have never sold. Last year for carburetor 318.
Huh.... Every 88 318 I have ever seen in a truck/van has been that crappy TBI... The diplomats and the fifth avenue cars with 318s stayed carb'd all the way to their demise, in 89 the 88 pick up I had was the worst 1 Ive ever had, was 1st year for EFI. They say not to but any "1st year for a new system". Ran ok but was by far my worst gas hog.... My full time 4wds, my 78 dually were even better in that department. I can't say how much money I spent in just trying to improve on that one aspect, I wound up selling the truck because of it .... It's rare I don't keep a car or truck long enough to be the guy that takes it across the scale ... I generally run em right into the ground.87 was not the last year of the 318 carb. Before my 92 B250 I also had a 1988 B250 with a 318 that had a four barrel carb. Even though I rebuilt the carb I can’t remember if it was a quadrajet or a thermoquad. My 92 had fuel injection.
My 88 was towed to the junk yard with 342k miles on it. Besides routine maintenance the only thing mechanical I had to do to it was replaced an alternator, power steering pump and transmission. It served me well.Huh.... Every 88 318 I have ever seen in a truck/van has been that crappy TBI... The diplomats and the fifth avenue cars with 318s stayed carb'd all the way to their demise, in 89 the 88 pick up I had was the worst 1 Ive ever had, was 1st year for EFI. They say not to but any "1st year for a new system". Ran ok but was by far my worst gas hog.... My full time 4wds, my 78 dually were even better in that department. I can't say how much money I spent in just trying to improve on that one aspect, I wound up selling the truck because of it .... It's rare I don't keep a car or truck long enough to be the guy that takes it across the scale ... I generally run em right into the ground.
on your carb anything newer than 84 would have been a quadrajet. Thermoquads ended in 84. Which is a shame because I really liked those. Had great service out of them back in the day. I always hated any carb that said "HOLLEY" on them. Those are the ones I never had much luck with.
I like the looks of that already. I want to build a bucket type roadster or rat rod so bad. A lot of the non running riding mowers would be a good candidate. That’s what my plan was for the Hoopdy I got but the darn thing runs and cuts so well I just couldn’t cut it up.I got bored today. I started pulling parts out of the corners and auditioning them together.
I've got hydro transaxle out of a Cub Cadet, an 18 horse Vanguard, a Cub Cadet front axle, a pair of 26-12-12 tires and rims, some Sears fenders, an old race car seat, and an old bus seat. Haven't looked steering yet , but I have a power steering set up from a Cub Cadet to play with.
Don't know if I want a "Swamp Rat" look or just a "Butt Buggy".
