Had to get back into the JD 265 today! Remember this is a Kohler V-Twin repower. Anyways, I started it several days ago. Let it run for a few minutes.
Went to start it the next day, no go! Got crazy with the carb cleaner and blew one end out of the muffler.
OOPS! Decided I would find it's issue today!
Took all the air cleaner housing off, pulled the NEW solenoid out of the NEW carb. Tested it and it's bad. Got the old one from the other carb and it still worked.
Tried to start it. Nope, wasn't happening. Checked spark, compression (thumb over plug hole), pulled the valve covers. Valves are working. Gotta be the flywheel key.
Took the top off the engine and made my way down to the flywheel. Got it pulled and sure enough, I had sheared the STEEL key.
Found a replacement in my stash. Got the flywheel back on, reset the magnetos to spec. Hit the key and it fired back off. Took another hour to reinstall all the parts. Waiting for the local Atwoods to get some Argon mix gas for my welder so I can try to fix the muffler. Been 3 weeks now!
