While slime does the trick it also eventually ruins the rims if tubeless . Found out the hard way a few times..If they are not any better than the HF tires and tubes they are not worth a nickle in my book.
Every thing I have with HF tires on it has slime in it to keep air in them. From bicycle tires on the torch cart to the two on the tiller.
It also makes a big mess if you do eventually have to take the tire off…While slime does the trick it also eventually ruins the rims if tubeless . Found out the hard way a few times..
Never seen where slime ruin any rims but haven't taken any apart with slime in them.While slime does the trick it also eventually ruins the rims if tubeless . Found out the hard way a few times..
Usually cheaper to replace the whole wheel than to try to fix a leak in one of their tires. Even their tubes seem to leak all over the place.It also makes a big mess if you do eventually have to take the tire off…
After much comparison, the model is a 608 with the G-deck. No idea he year. Possibly early 2000s.WOW, we ordered the 3 belts off V-Belt Supply on Monday night, 7pm. They arrived this afternoon ! On the order, it said 5-7 business days.
There is another website for Lawn Tractor Wheels.
Two new wheels on rims with tubes for $59 shipped.
We'll see how long it takes for the arrival.
SET of 2 - 13x5.00-6 Dark Gray Turf Tread Lawn Mower Wheel Assembly
Compatible with a variety Craftsman models, including the Rer 1000, and more.lawnmowertirestore.com
One wheel like this on Amazon was $60, a pair for $115.
