What the best?
Well here the hoard. I'm hoping I can get the troy bilt running, the Murray supposed to run. Really the plow all I went after, and I'm ashamed of what I payed for it :oops:
Naw thats nothin'... when ya start makin deals that require three trips... then you Might have a problem ;)
Well the troy bilt started on either. It shows 416hrs on it, I don't know if that good or bad the stuff I fool with that just 2 oil changes lol. It appears to have a oil leak on the bottom too it getting on the pulley. Dose anyone know if that something common on those twin cylinder briggs? It's a 21hp ohv intek
Its fairly common, mostly on engines that havent been run for a long time, twins and single cyl... $5 part but you have to pull the engine to replace them. Check to make sure the crankshaft isnt bent before you tear things apart.
