I know of an 8N rim needing some work too.Used the hot wrench to form the patch close enough to weld. It should keep the tube on the inside.
Pull the hole---LOL! Nice job CJet!Before priming I looked at the valve stem hole and noticed the other wheel has the hole in the middle of the radius rather than on the flat of the rim. It took a lot of force but I managed to pull the hole around to the proper location. After that I got it sprayed with epoxy primer. Not sure what color to spray the wheel with. I think originally they were white or off white. I may go with the silver IH wheel paint planning on someday spraying them all.
At least I didn't say pull my finger.Pull the hole---LOL! Nice job CJet!
Probably said it before Cjet but once the wheels are painted the rest of the tractor is just begging for it too..Did a quick paint job on the wheel. Hopefully I can put it back on the tractor tomorrow so I can finish the shop cleanup.
HEY! Don't add another project to my list I have enough already.Probably said it before Cjet but once the wheels are painted the rest of the tractor is just begging for it too..
Don't you just love it when people make more work for ya...?HEY! Don't add another project to my list I have enough already.
I might paint the rest of the wheels to match eventually but doubt i would ever paint the rest of it. I couldn't use the tractor with a flat tire but it will work fine without a repaint.
Oh no....Mounted the wheel weight and moved one Datsun engine. I'll get the other 2 moved tomorrow.
Bolting the wheel weight on will help hold the paint on the wheel.Oh no....
You hid that those nice new painted rims.......!
